QG_GraphicView::paintEvent conditions
if (redrawMethod & RS2::RedrawGrid)
if (redrawMethod & RS2::RedrawDrawing)
if (redrawMethod & RS2::RedrawOverlay)
RedrawNone = 0
RedrawGrid = 1
RedrawOverlay = 2
RedrawDrawing = 4
RedrawAll = 0xffff
https://en.wikipedia.org/wiki/Bitwise_operation#AND
I don't understand the point of these expressions.
If 0xffff & 2 evaluates to true, then 0xffff alone will evaluate to true.
If 0 & 2 evaluates to false, then 0 alone will evaluate to false.
Isn't the right side superfluous?
In otherwords, can't we just simplify it to one condition: if (redrawMethod) ?
Re: QG_GraphicView::paintEvent conditions
RedrawNone = 0
RedrawGrid = 1
RedrawOverlay = 2
RedrawDrawing = 4
RedrawAll = 0xffff
It evaluates to 2, not to true
0xffff & 0 evaluates to 0, there is no 0xffff alone here
If one method says
redrawMethod = redrawMethod | RS2::RedrawGrid
and a other methods says:
redrawMethod = redrawMethod | RS2::RedrawOverlay
Then only these two get executed, but not redraw of the drawing.
makes sense?
Thanks for the reply.
I misunderstood how the & operator worked before;
however, I still don't see the need for bitwise operators.
It seems like this system was written so that the least amount of people could understand it.
There has to be a way to simplify this to three bool member variables;
although, I'm not sure if it would be worth the effort to rewrite everything.
Something I noticed in testing is that the "if (redrawMethod & RS2::RedrawOverlay)" block
is processed when the mouse is moved in the drawing area in the default selection mode.
using binary flags makes sense, as the flags are supposed to support any combination of on/off flags.
Binary flags are common implementation in Qt, for example:
http://doc.qt.io/qt-5/qsizepolicy.html#PolicyFlag-enum
