RDCAM 6.0.44 problems with dxf librecad
joselito100
Software laser cut RDCAM 6.0.44 for Widlaser LS-40B machine accept dxf until DXF R12 but the dxf build with Librecad do not work. I try all the dxf export in librecad.
Best regards
José Lorenzo
Re: RDCAM 6.0.44 problems with dxf librecad
Welcome José,
sadly, there is not much value in your post to dissect your topic.
Generally, I assume, that you have to ask the guys from RDCAM what's wrong with your DXF files.
I'm afraid that here nobody can tell you why RDCAM doesn't like your DXF files. Maybe there are requirements we don't know at LibreCAD, so your chances are higher when you ask in RDCAM related resources.
But if you expect some kind of help, give more information about your issue. If you don't know what I mean, search the web for "good support request".
If you have issues with drafting in LibreCAD, here is the right place to ask.
joselito100
Ok, thank you for your answer. In the future I try to get more information...
Best regards
José Lorenzo
