Reading ASCII points
7 messages Options
Broomy
One of the new features of the daily update is importing points with an ASCII-file. (File-->Import-->ASCII points)
So far I haven't been able to do so.
Did anyone succeed?
Re: Reading ASCII points
Works for my:
From this thread (10 months old):
http://forum.librecad.org/LibreCAD-for-mapping-td4549798.html
File->Import->Read ascii points
Simply change "format" to "Comma separator" for CSV files
The format of the data expected by the plugin are (code not mandatory):
number,x-coordinate,y-coordinate,z-coordinate,code
like:
1,257.65,354.25,0.0,wall
2,293.58,355.98,0.0
3,315.12,357.37,door
The "format" is the most important, if you select "Comma separator" and the file
is "space separator" the plugin do not work.
broomy
Thanks Rallaz,
It works fine now!
Siprex3D
Hello all
I understood your explanation about CSV format,
But on my LibreCAD (version 1.02 for Windows) "Import" in file menu is not avaible (grey).
I would like to try  asciifile1.dll but i didn't find "plugIn folder"
Thanks for your support
Siprex3D
Thank you for the fast answer.
I discover that shp format is included. That great! I Am very interested in GIS...
One of my friends is teacher in a geographic academy.
I would like involved some GIS students in plugin project for LibreCAD.
Could you tell me where i can found some documentation about that?
Hello Siprex3D,
the shp import plugin is incomplete, at least multipoint shapes are not haldled.
If you want to collaborate might complete the plugin.
Another GIs related feature are add support for DGN files. You can start using
the skeleton of importshp plugin and libdgn from ogr:
http://www.gdal.org/ogr/drv_dgn.html.
To learn about LC plugin creation you can read (outdated):
https://github.com/Rallaz/LibreCAD/wiki/Write-plugins-HOWTO
and read the fully documented file:
librecad/src/plugins/document_interface.h
