Reference Scale
Reference Scale
larrangeur
I was wondering if it was possible to add an reference option in the scale fonction.
Very usefull for blueprints, you import an image, scale and draw a line on the blueprint, specify the final size and go !
Hope this function is useful for other people.
Thanks for your great work !
Re: Reference Scale
seems to be connected to "General factor" of the dimensions.
Could you described a detailed ideal use case? Just because you have more experience here.
Re: Reference Scale
larrangeur
The situation is the following :
You want to have a scaled blueprint in your drawing.
- Import the jpg blueprint (which has a scale or a distance on it)
- to scale the blue print, click on the begin point of your scale
- click on the end point (by point i mean somewhere on the picture, not a CAD point)
- type "1000" for exemple if your scale was 1 meter
- Voila ! Your blueprint is scaled
The point is to prevent you from calculating the scale factor
Loading...
