"Inkscape seems to show roughly the same numbers as FreeCAD..."
That's strange. When I draw a 100mm x100mm square and set the resolution to auto and the borders to 0,
I get a "35,631mm" rectangle.
When I do (in Inkscape) Path->Object to Path, the length of the upper line is "35,278mm" (the thickness of the line/cap is not included here).
Can you please tell, what version of LibreCAD 2.0.0 you are using (rc1,rc2, beta,...)?
And what operating system you are using (also if 32/64bit).
A simple workaround is to open the exported svg file and set the width/height (should be the second line of the file) to the size you want. But you should take the thickness of the line/cap into acount.
<svg width="35.2778mm" height="35.2778mm"
