Same Properties plugin
Philip
I am trying to use the Same Properties plugin but I don't know if I'm doing something wrong or the plugin has a bug.
I select the Same Properties plugin and click on the original entity.  I then click on the entities to change.  Hit the enter key and nothing happens.  For example, I select a circle with a .625 diameter, the original entity.  Then I select one or more circles with a diameter of .1.
Is it me or the plugin?
Re: Same Properties plugin
Haven't tested it thoroughly, but I think Same Properties only regards Pen Properties (line colour, width and type).
Philip
Right you are Dellus.  I changed the attributes of one entity to a different color then ran the Same Properties plugin and the color of the entity did in fact change color also.
Thanks for the info.
