Setting up a scaled drawing on 24x36 sheet??
rjf
rjf
I am new to this process and am wanting to use a 24x36 architectural sheet format.
How do you set up, for example, 1/4"=1'-0" drawing on a 24x36 sheet?
Should you actually save a sheet as a block that is literally 24x36 in size?
Or should you be drawing in real world measurements such as 1'-0" = 1'-0"?
And if so how do you set up a 24x36 sheet for printing?
Thank you in advance for any assistance!
rjf
Re: Setting up a scaled drawing on 24x36 sheet??
In Options - Current Drawing Preferences - Paper you set your paper sheet, 24x36 inches is Arch D, isn't it? (I'm European, so don't know). In - Units you set inches. In Dimensions you set the values for dimensioning, a little complex. General scale is for the scale, for 1/4"=1'-0" you set 48. The size of letters etc can then be set in real on paper size. of Note that up to V 2.1.3 fixed extension line length does not submit to General scale, in V2.2 it does.
You always draw in real world measurements.
In Print Preview set your scale (1:48). If you use a frame, it has to be drawn 48 times the size. With frame use "Center to page", otherwise move the white sheet manually with the mouse cursor. Print from within Print Preview mode.
I have prepared a sample drawing: arch_inch_1_48_arch_d.dxf
Here is a manual: https://wiki.librecad.org/images/2/20/LibreCAD_Users_Manual_2.1.3.pdf
rjf
rjf
Thank you for your response it is much appreciated.
Is this done under drawing preferences? Where do you set it to "48"?
Where is this set in print preview? Could not find a way to do this.
The size of letters etc. can then be set in real on paper size.
This is set to 1?
A frame is a physical sheet I have drawn in Libre? So scale it up 48 times?
rjf
48 is not in the drop-down list, you have to type it in manually.
Again, 1:48 is not in the drop-down list, you have to type it in manually.
This is set to 1?
This refers to text height, arrow size and other things in dimensions. So if you are in inches, you might want a text height of 0.1 inches, near to 2.5 mm on paper, which is standard for normal text.
If you want a frame of 24x36 inches, like your paper sheet size, you have to draw it 48 times larger, 1152x1728 inches, because when printed it's scaled down again.
That "General Scale" thing only works on dimensions.
Try out the sample drawing I have attached and study the settings in "Current Drawing Preferences".
The inner rectangle with the dimensions is just a symbol for maybe a ground plan.
Also study the manual I have added a link for. It is quite comprehensive.
