Show content of MTEXT on "List Entities"
am
am
When I order a "List of entities" ("Plugins", "List entities"),
I´d like to see the text contents of a MTEXT or TEXT:
n 163: MTEXT
  Layer: 0
  Color: BYLAYER
  Line type: BYLAYER
  Line thickness: BYLAYER
  Text : "THIS\r\nIS\r\nA\r\nTEST!"
\r is CR
\n is LF
\t is TAB
\" is "
From what I´ve seen, changes should be made on "list.cpp":
    case DPI::MTEXT:
        strData.prepend( strEntity.arg(tr("MTEXT")));
        strData.append( um... err.....   strCommon.arg(tr("Text")).arg(   safe_string(data.value(text).toString())  ); ????
        break;
    case DPI::TEXT:
        strData.prepend( strEntity.arg(tr("TEXT")));
        break;
QString safe_string(QString src)
        QString result = "";
        char tmp[8];
        for (int i=0; i<src.length; i++)
                char c = src[i];
                if (c < 32)
                        switch (c)
                        case '\r':
                                result += "\\r"; // Add \r
                                break;
                        case '\n':
                                result += "\\n"; // Add \n
                                break;
                        case '\t':
                                result += "\\t"; // Add \t
                                break;
                        default:
                                sprintf(tmp, "\\%02X", c); // Add \00, \01, ...
                                result += tmp;
                                break;
                else
                        switch (c)
                        case '\\':
                                result += "\\\\"; // Add \\
                                break;
                        case '"':
                                result += "\\\""; // Add \"
                                break;
                        default:
                                result += c;
                                break;
        return result;
This suggestion is posted in:
https://sourceforge.net/p/librecad/feature-requests/
http://librecad.org/cms/home/get-help/forum.html (suggestions & feedback)
am
Re: Show content of MTEXT on "List Entities"
am
I realized I could do what I wanted by reading the DXF file with C# program!
