Suggested mod to qc_applicationwindow.cpp - LibreCad 2.1.3
mad-hattter
This stops a warning when using GCC/G++ and compiling from wthin Qt creator. (Windows 10 - 32bit)
Warning:- event unused
void QC_ApplicationWindow::changeEvent(QEvent* event)
    // author: ravas
    if (event->type() == QEvent::ActivationChange)
        #if defined(Q_OS_MAC)
            // returning to LC via Command+Tab won't always activate a subwindow
            // https://github.com/LibreCAD/LibreCAD/issues/821
            if (isActiveWindow())
                if (current_subwindow)
                    mdiAreaCAD->setActiveSubWindow(current_subwindow);
            else
                current_subwindow = mdiAreaCAD->currentSubWindow();
        #endif
//    #if defined(Q_OS_MAC)
//        // returning to LC via Command+Tab won't always activate a subwindow
//        // https://github.com/LibreCAD/LibreCAD/issues/821
//        if (event->type() == QEvent::ActivationChange)
//            if (isActiveWindow())
//                if (current_subwindow)
//                    mdiAreaCAD->setActiveSubWindow(current_subwindow);
//            else
//                current_subwindow = mdiAreaCAD->currentSubWindow();
//    #endif
Re: Suggested mod to qc_applicationwindow.cpp - LibreCad 2.1.3
Thanks for reporting this.
In the latest sources this is already solved, see latest source on github.
I'll check the stable 2.1 branch. As this is only cosmetics, it will not trigger a new bug fix release.
But if there will be one in future, I'd be glad to patch this.
Generally we have to check another issue with this method. As changeEvent() is an override, there maybe problems because the event is not forwarded to the base class. This is true for the latest sources too.
Many thanks for your efforts.
