Text file
Text file
ultra
Is it possible to import a text file which contain plot coordinates and have the plot coordinates plotted automatically by LibreCad?
Waldo
Re: Text file
I think the Read ascii points plugin is what you are looking for.
See http://forum.librecad.org/Reading-ASCII-points-td5706664.html
Re: Text file
ultra
Thanks.  I looked at that awhile back, and wondered if there wasn't a more direct and simpler way.  Have you used this method?
Waldo
Re: Text file
No, I had not, never had a use case for this plugin.
If the plugin is too inconvenient for you, have a look at this:
http://forum.librecad.org/Key-Mode-Load-Command-File-Paste-Multiple-Commands-tp5716611p5716614.html
Most information for Load Command File and Paste Multiple Commands are linked in my reply there.
I think the first version with these features was 2.1.2
Re: Text file
ultra
Hello Armin!
With regard to subject plugin:  LibreCAD manual, accessed via LibreCAD "Help" menu,  shows an interesting example, at very end,  on how to plot text file coordinates.  Here is a screen shot of the plugin as noted in the example.  I've followed the example's instruction, and the result prints a single line of garble at the bottom of LibreCAD work area.  I copied an pasted text list noted in the example and saved it as a text file (.odt).  Created a layer and named it (t1).  NOW!  I go to File - Import ( Verision 2.1.2) gives two options to import, Image or Block.   Any ideas!  Thanks Armin.
http://forum.librecad.org/Text-file-tp5717178p5717179.html
To unsubscribe from Text file, click here.
Screenshot from 2019-04-02 11-38-59.png (347K) Download Attachment
Waldo
Re: Text file
ultra
After further research I've discovered my inquires  on this matter is covered, seemingly, in depth.  Thank you Arimin, and please disregard my latest email on subject matter.
On 4/2/19 12:28 PM, ultra [via LibreCAD] wrote:
Hello Armin!
http://forum.librecad.org/Text-file-tp5717178p5717193.html
Waldo
