Quantcast
Text size for dimensions
star
procer
Hello, I don't know if it's a feature or not, but is it possible to change the size of the text in a dimension?
I'm working with some small models, so basically once I've laid out the dimensions it's just a huge clutter of numbers.
Trying: modify>text> *click on dimension*
a pop-up titled linear dimensions comes up where one can enter text, but there's no size option.
my version is 1.02
star
Re: Text size for dimensions
Hi procer
"Edit->Current drawing preferences"
select "Dimensions" Tab and change
"Text Height", "Arrow size", etc.
star
procer
Awesome, thanks :)
star
grypokx
Hi procer,
Modify>explode the dimensions.
Modify>Properties and select the text.
now you can modify just the text in the dimension.
This is because a drawing could contain multiple text sizes.
To rallaz,
Is it possible to make the arrow as an object (a hatched triangle) after executing above procedure?
This because sometimes i just want to scale it off manually.
star
For my, this is a bad idea, without exploding dimensions if you
 modify "Current drawing preferences" all the dimensions are
changed automatically. Exploding it you have to change one to one
A drawing can contain multiple text sizes. But only one dimensions text size.
in a near future will be implemented dimension styles and may have
dimensions with different text size without having to exploit
grypokx wrote
To rallaz,
the arrow is a TRACE entity, and have a poor support, at this momment, the best option is select,
draw lines arround using "end point" snap, then "supr" the trace and add a hatch.
star
grypokx
hi rallaz
yes, yours provides the correct  and neat way of doing it.
Sorry, mine actually create more problems..:D
grypokx
Loading...
