Toolbar creator
Toolbar creator
AnTeaX
I used the Widgets/Toolbar creator feature to group all the tools I use on one toolbar. It works.
I want to modify that toolbar. The program crashes every time I try to access the Widget/Toolbar creator.
I tried to Uninstall and re-Install after deleting the file in AppData\Local\LibreCad but no change, the program still reopens with my toolbar, so I guess there is a file somewhere else which keeps my settings and is re-used even after uninstalling.
Thanks for your help.
Re: Toolbar creator
If you are willing to start from all default settings:
Application Preferences -> Defaults -> Clear Settings -> All
That will also delete all custom widgets.
Otherwise you need to edit the registry.
http://doc.qt.io/qt-5/qsettings.html#platform-specific-notes
.../LibreCAD/CustomToolbars
