Trim / Extend broken by commit d09d9ceae79
Tim Moore
The border range test introduced by d09d9ceae79 breaks Trim / Extend for lines that do not overlap in X or Y. Recreate by trying to trim one line against another that is, for example, completely above it.
I think the fix is to do the bounds test only after checking that one of entities isn't a line. In any event, reverting  that commit fixes Trim / Extend.
Do you want an entry in the bug tracker for bugs that are only in the master branch and for which the problem is identified?
Tim
Re: Trim / Extend broken by commit d09d9ceae79
Tim,
I just added your patch in your previous mail in the bug tracker.
It would be helpful indeed if we record all issues in the bug tracker because on the forum they will properly get lost.
Thanks for your support!
Ries
Tim
http://librecad.1049103.n5.nabble.com/Trim-Extend-broken-by-commit-d09d9ceae79-tp4778058p4778058.html
