Quantcast
Trim
Trim
Dermott
Has anybody else had a problem when trying to Trim using two 'cutting/trim' edge? When I select this option in the command prompt it states to select the first trim edge (once selected this the entity changes colour). The prompt changes to select the second trim edge, when this is selected nothing happens and the command is aborted.....any ideas?
Note Triming using one cutting edge works fine
Dermott
Re: Trim
I can only reproduce this if the second trim entity is on a locked layer. Otherwise no idea.
Loading...
