Troubleshooting
Post to this forum if you are experiencing problems with LibreCAD
*Please mention your operating system and LibreCAD version - this will enable us to advise you properly.
*Report bugs here:
https://github.com/LibreCAD/LibreCAD/issues
1234567 ... 11
Topics (360)
Replies Last Post Views
lj dwg support? by lj
12
librecaduser by librecaduser
Zmogas [bug] faulty command window when it is detached by Zmogas
5
ravas by ravas
Civil Guy Text Issues by Civil Guy
1
ShayWalters by ShayWalters
oc3ansoul Custom size of objects and placement by oc3ansoul
2
oc3ansoul by oc3ansoul
savio workaround to ltscale by savio
1
dellus by dellus
Cantar4 MacOS LC versions fooled by El Capitan by Cantar4
8
Cantar4 by Cantar4
norrsken v2.1.0 unusable - fatally slow with larger files by norrsken
16
jaise by jaise
sashman Tangent 2 Circles, Radius - How does it work? by sashman
6
sashman by sashman
psytag Dimensions formatting by psytag
2
psytag by psytag
Cantar4 Auto zoom troubles with 2.1 beta 4 by Cantar4
30
ravas by ravas
Cantar4 Impossible to copy/paste from '0' to another layer by Cantar4
8
ravas by ravas
Ajohn Drawing lots of holes / circles on a pitch circle diameter by Ajohn
2
Ajohn by Ajohn
Ajohn Troublesome little red circle with cross after a mistake by Ajohn
5
Ajohn by Ajohn
FRK Ledger page format rotated in PDF Export by FRK
1
FRK by FRK
Ehpar Can't dimension any mnore. by Ehpar
1
dellus by dellus
eslavko Import image resolution. by eslavko
4
eslavko by eslavko
Cantar4 Fillet radius insertion freezes the drawing by Cantar4
3
ravas by ravas
tryagain dxf show error by tryagain
0
tryagain by tryagain
ben83 IMPORT DXF AND NOT SHOWING BLOCKS by ben83
18
Cantar4 by Cantar4
Christian Some letters turn capital when exploded by Christian
0
Christian by Christian
Christian Lengthen tool's strange behaviour on ellipses by Christian
5
ravas by ravas
Christian Bugg on Offset tool in Modify by Christian
2
Janno F5 not working in Windows 10? by Janno
7
Janno by Janno
Tocdub 2.09 crashing in windows by Tocdub
3
Tocdub by Tocdub
radar opening dwg file fails by radar
4
ravas by ravas
Christian Polyline: Create Polyline from Existing Segments by Christian
2
Christian Polylines strange behaviour by Christian
0
Christian Polyline Angle, another strange behaviour by Christian
4
Christian Arc Tangential: strange behaviour by Christian
8
dxli by dxli
dubser [Solved] Text tool trailing caracters in drawing. by dubser
3
dubser by dubser
Christian Fillet Trim option by Christian
5
Christian No Tool Option for Concentric Arcs or Circles by Christian
0
Jim Thompson Adjusting the printer to print dark lines in LibreCad drawings. by Jim Thompson
15
dellus by dellus
wynnjones Librecad crashes by wynnjones
11
wynnjones by wynnjones
dubser Newbee no object selection. by dubser
2
dubser by dubser
1234567 ... 11
