Unable to run lua Script in LibreCAD 3
Amarjeet Kapoor
hi, I am tried to run example on LibreCAD manual
http://wiki.librecad.org/index.php/LibreCAD_3_-_Lua_Scripting
But I am getting folowing error [string "d=app.currentDocument();..."]:1: attempt to index a nil value (global 'app'"
Any help regarding this?
Re: Unable to run lua Script in LibreCAD 3
Amarjeet,
these examples might be out dated.
There are some other examples here, see if these work : https://github.com/LibreCAD/LibreCAD_3/blob/master/lcadluascript/lcadluascript.cpp
Ries
On 19 Sep 2016, at 03:13, Amarjeet Kapoor [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/Unable-to-run-lua-Script-in-LibreCAD-3-tp5714246.html
Amarjeet Kapoor
On 19 September 2016 at 13:08, R. van Twisk [via LibreCAD]
> Amarjeet,
I tired Lua code in above link but after that even LibreCAD is also not opening
amarjeet@amarjeet-Inspiron-3521:~/projects/LibreCAD_3/build/lcUI$ ./librecad
log4cxx: Could not open file [Log4cxxConfig.xml].
Amarjeet Singh
https://amarjeetkapoor1.wordpress.com
https://github.com/amarjeetkapoor1
https://bitbucket.org/amarjeetkapoor
"The journey of a thousand commit begins with a single init"
Don’t worry about,
It’s a warning, not an error. If LibreCAD doesn’t open (I assume you mean start) it’s not because of that.
Ries
On 20 Sep 2016, at 11:39, Amarjeet Kapoor [via LibreCAD] <[hidden email]> wrote:
<<a href="x-msg://21/user/SendEmail.jtp?type=node&amp;node=5714250&amp;i=0" target="_top" rel="nofollow" link="external" class="">[hidden email]> wrote:
> Amarjeet,
Amarjeet Singh
http://forum.librecad.org/Unable-to-run-lua-Script-in-LibreCAD-3-tp5714246p5714250.html
Amarjeet Kapoor
On 20 September 2016 at 15:16, R. van Twisk [via LibreCAD]
> Don’t worry about,
I know that as It used to appear even before LibreCAD doesn't open GUI
interface . I just posted that to show that even no error is shown on
terminal.
And I think we can't say it doesn't start as after ./librecad command
it doesn't exit but Just GUI is not shown.
Amarjeet Singh
On 20 Sep 2016, at 11:53, Amarjeet Kapoor [via LibreCAD] <[hidden email]> wrote:
<<a href="x-msg://24/user/SendEmail.jtp?type=node&amp;node=5714252&amp;i=0" target="_top" rel="nofollow" link="external" class="">[hidden email]> wrote:
> Don’t worry about,
terminal.
Ok,
please let us know the solution and what happened.
Ries
Amarjeet Singh
http://forum.librecad.org/Unable-to-run-lua-Script-in-LibreCAD-3-tp5714246p5714252.html
