Updates for 2.0 (Ubuntu) do not distinguish the thicknesses of the lines (SOLVED)
7 messages Options
joaclint
Hi all. Sorry for my english
My problem is that last updates do not show the different thickness for lines, arcs... now all the draw is in 0.2mm (more or less). Curiously, libreCAD 2.0 (via APP for Ubuntu) shows the right thickness while drawing the line but at the second clic gets 0.2mm
Do you know something about it?
Thanks
Re: Updates for 2.0 (Ubuntu) do not distinguish the thicknesses of the lines
Hi joaclint,
I'm the one to blame for recent painter problems. I have been preparing for 2.0.0alpha4 tagging, with painter improvement a blocker here. The main goal here is to make sure line patterns defined properly in size, and avoid drawing line segments out of viewport.
If possible, please attach a sample dxf file for me to troubleshoot this bug. The file should contain entities of various line thickness values.
Thanks,
Thanks
joaclint
Thanks a lot.
Here it is a screenshoot wirh the problem.
imagen_librecad
And here it is a DXF that was ok untill this problem and now i see with all lines with the same thickness:
GNU/Linux Ubuntu 12.04
LibreCAD 2.0.0 alpha3 June-16-2012
joaclint
Hi.
In the last update (June-25-2012) the problem continues.
I will be waiting for Alpha4.
Thanks a lot
I can not reproduce this still from the latest HEAD of master branch: 37700fa71b731
https://github.com/LibreCAD/LibreCAD/commit/37700fa71b73140723ca15ddb8e7688e41b6a4ca
LibreCAD line width
The modified dxf file
cajetin_170_ancho.dxf
Might this be because the draft mode that is one for this person?
Ries
LibreCAD line width
http://forum.librecad.org/Updates-for-2-0-Ubuntu-do-not-distinguish-the-thicknesses-of-the-lines-tp5706783p5706833.html
joaclint
OMG!!!
Yes, it was... Draft Mode was enabled. May be one update checked it automatically.
Now it is all ok.
