angular dimensions above 180°
pwp
pwp
How can I indicate angular dimensions above 180°? The tool always extends the ray from which I start. This way the first 180° always gets cut off...
Angular dimension >180°
The angle above should be measured as 225° in stead off 45°...
Re: angular dimensions above 180°
Angular dimensions were revamped in version 2.2.0-rc1. With that version angular dimensions > 180° are possible.
Before that version angular dimensions are always <= 180°.
For Windows you can use latest nightly build from SourceForge.
But for other OS we currently don't have nightly builds.
rolgiati
On Wed, 29 Aug 2018 06:21:13 -0700 (MST)
> <https://sourceforge.net/projects/librecad/files/Windows/NightlyBuilds/master/>
Have you tried using a negative angular dimension ? (if N° > 180, using 360° - N°)
Cheers,
Ron.
    In mathematics you don't understand things, you just get used to them.
                                                       -- John Von Neumann
