background color of a rectangle
7 messages Options
Jean in France
due to librecad ease of use and your help, in two days I could build a complex drawing. It is mainly a lot of rectangles. To visually separate one another, I use hatches. But is it possible to 'color' the inside of a rectangle instead of using hatch ?
I set a chechbox in the hatch window but the color is only white ... and I would like 'light grey' !
TIA
Jean
Re: background color of a rectangle
mad-hatter
Jean in France
Thanks,
I'll try that this week-end ...
BYTW what explained 'Aussie' is what I am thinking and doing : LibreCAD is wonderful and I use it for my hobby : 'model railroad' (in fact the table where I'll will build it).
Jean
grherr
In reply to this post by Jean in France
On 08/11/2017 12:25 AM, Jean in France [via LibreCAD] wrote:
TIA
Jean
http://forum.librecad.org/background-color-of-a-rectangle-tp5715203.html
To unsubscribe from LibreCAD-user, click here.
Jean,
Try checking the "Solid Fill" check box in the Hatch dialog and close it. You should get a white fill in the rectangle. Then select the fill area and bring up Tools | Modify | Attributes and change the color. That worked for me.
HTH.
Girvin Herr
Jean in France
HI,
Mad-hatter, I couldn't find the 'create hatch' tool !!
Grherr, it worked for me too. Thanks.
I have a 'wish' : being able to 'color' with a RGB value (ie 128,10,96) !!!
Best Regards
Jean
In the attributes checkbox choose "Custom" for the colour, an other checkbox will come up where you can set RGB values.
Jean in France
Hi Dellus,
it works like a charm !!
Thank you.
Jean
