can't see text on dimensions
russellf
Hi
I am very new to LC, I installed the latest version today
Version: 2.1.3
Compiler: Clang 8.0.0
Compiled on: Sep 22 2016
Qt Version: 5.6.1
Boost Version: 1.60.0
My current issue is that when I add a dimension the text is so small that it isn't legible either on the screen or when it is printed.
Google turns up several similar issues mostly from much earlier versions and instructions don't seem to match the current version.
Any help much appreciated!
Re: can't see text on dimensions
The text height and other size settings for dimensions have to suit to the size of the drawn object, units and intended (printing) scale. So if it's a mechanical part in mm, let's say 250mm long and to be printed in 1:1, the preset values in options - current drawing preferences - dimensions might do it. But if it's a building, in meters, to be printed in scale 1:100, you will have to change these settings. With 'general scale' you can modify all the values (except 'fixed length'), so you don't have to change all the individual values for a different scale. Also ensure a paper size is set.
russellf
Thanks Dellus
I figured that the issue was scaling what I could not figure out was where to change it. Once I know what to look for I found it at:
Options -> Current Drawing Preferences ->Dimensions ->General Scale
I suspect that is a common gotcha for newbies and it might be worth a paragraph in the manual.  I'd write it myself but I am hardly qualified with a few hours fiddling!
Russell
ruprect
I had the same problem, finally figured it out but also wasted a lot of time. I've been messing with Librecad for a couple of years and have yet to get it to be useful. I just installed 2.1 (linux) hoping it was fixed, it's different but still not useful. I'm a toolmaker and use CAD every day for the last 30 years so I'm not a newbie but I prefer Linux and wish there was a usable Linux 2D CAD application, Librecad is not it.
sp1der
You need to use QCAD my friend, Librecad was based on qcad old code anyway. Currently even the free version of qcad is so much better than using librecad.
In my opinion librecad is just re-inventing the wheel here -a waste of time!
Milemete
Thanks for that. I'll give it a try
http://forum.librecad.org/can-t-see-text-on-dimensions-tp5714303p5714386.html
To unsubscribe from LibreCAD-user, click here.
Avast logo
This email has been checked for viruses by Avast antivirus software.
www.avast.com
