change the grip size
8 messages Options
jaise
How can i increase size of grip handle. It is too small in size.
Grip very small
If it is activated on single click [on grip handle], it will be very useful.
Re: change the grip size
jaise
In reply to this post by jaise
looks like we have the same issue of small sizes on higher resolution displays.
jaise
Some grip details from Zcad [http://sourceforge.net/projects/zcad/].
Source code available at http://svn.shamangrad.net/zcad/trunk/
Are you interested in programming?
void RS_Painter::drawHandle(const RS_Vector& p, const RS_Color& c, int size) {
    if (size<0) {
        size = 2;
    fillRect((int)(p.x-size), (int)(p.y-size), 2*size, 2*size, c);
jaise
I have not any programming earlier. But we have some subject during study.
jaise
But current ortho mode, we have to enter both axis [example 150,0]. So there is no much use during actual dwg.
Usually most of 2D dwg contains 80% to 90% lines are ortho. So If ortho work improved, So much time can be saved during dwg preparation.
During ortho, if we able to input only 150 neglecting 0, it will be very easy & save lot time during dwg.
jaise
sizing of handle with factor of 2.5 is OK.
    if (size<0) {
        size = 2;
    fillRect((int)(p.x-2.5*size), (int)(p.y-2.5*size), 5*size, 5*size, c);
