change the pace of the grid
Claude Azoulai
Hello
I am a beginner on LibreCad and I can not change the pace of the grid that I want to adjust to 1mm or 0.5 mm.
How should I produce?
Re: change the pace of the grid
Gary S
The grid spacing can be 'fixed' in the Drawing Preferences.  From the menu, select Options->Current Drawing Preferences, select the Grid tab and specify the X Spacing and Y Spacing.  Also note that the Units (as defined on the Units tab) will affect the appearance of the grid.
Claude Azoulai
thanks to you
It seems to work
Claude Azoulai
Thanks Gary S
This only worked after saving the file and opening it again.
But it work
