changes to LibreCAD 3
@All,
in the goal to make the kernel Qt free I have removed almost all Qt classes from the kernel.
In return I added the following frameworks:
1) Nano signal slot (instad of CONNECT) : https://github.com/NoAvailableAlias/nano-signal-slot
2) Logging framework (instead of qDebug()) : http://logging.apache.org/log4cxx/
For all container classes we now use std::map, std::vector and friends.
At first I wanted to have a message bus instead of a signal/slot system but I couldn't find a suitable framework. Apparently this can be a hard subject specially when you want to create libraries. I think nano signal slot is very suitable for us and we can always visit a message bus later, the interfaces using c++11 look a lot alike...
The kernel is now Qt free!
Build has also been tested on linux mint.
Re: changes to LibreCAD 3
claus82
Good luck guys, see you soon here in the forum.
Best regards
Claudio
sp1der
Good luck Ries, I see you are making some progress, well done for your first hard work. Lets hope LibreCAD 3 will be with us soon.
