copying
copying
Screw
Objects of .. Ctrl+c .. Ctrl+v does not work?
Edit Copy ..Edit Paste does not work?
Re: copying
When you select "Edit->Copy" LibreCAD show "select toolbar" and wait to select the entities you want to copy.
1 "Edit->Copy"
2 select entities to copy
3 press button "continue action" in select toolbar
4 specify reference point
n "Edit->Paste"
Probably, the problem is "stage 2" the select toolbar is shown, but none message is print in the command.
I send a patch for the new version showing a message to select entities
Re: copying
cheperobert
This copying process is a little long
In Step Edit-> Copy, does not allow group selection.
There will be improvements in this part.
