crash on saving
11 messages Options
crash on saving
Lumaja
Saving or opening a file Librecad Quits.
How to fix this.
Thank you
Re: crash on saving
Please provide detailed information for us to investigate.
Like, version, OS, installer URL, and detailed steps to reproduce this bug.
How to fix this.
Thank you
Re: crash on saving
Lumaja
OS Ubuntu 12.04
LibreCad ver. 1.01
I don’t find any tutorial or manual for ver. 1.01 so I use User Manual for LibreCad 2.0.
After define a template and Save Drawing As to a folder the application stops with a error “The application LibreCad as closed unexpectedly”, the send report is marked, the generated report cant be copied.
Same happens on Open file, for some other reason the error window only shows once a day opening the application again and save file the error window does not show it just
closes.
Re: crash on saving
please upgrade to 2.0.6, as 1.0 series is not actively maintained.
BTW, 1.0.4 is the latest version for 1.0
Please help us improve our wiki on ubuntu installation: http://wiki.librecad.org/index.php/LibreCAD-2_Installation#Daily_and_Stable_Builds_in_Ubuntu_PPA
Lumaja wrote
OS Ubuntu 12.04
LibreCad ver. 1.01
closes.
Re: crash on saving
Lumaja
Upgraded and the version now is Ver. 2.07.
Same happens on Open file, for some other reason the error window only shows once a day Run the application again and save file the error window does not show it just closes.
Tried to save to other folders the same happens, experimenting, fond if save into the first three folders of Home they open and can be saved, but try the fourth folder or any other it closes.
Re: crash on saving
Lumaja
Open Terminal enter “librecad” it open with error in terminal but I carry on on saving file it close again sending result of Terminal it might help.
 luis@luis-G41M-Combo:~$ librecad
RS_DEBUG::setLevel(3)
RS_DEBUG: Critical
RS_DEBUG: Errors
RS_DEBUG: Warnings
Got bus address:  "unix:abstract=/tmp/dbus-O7dlqekdI5,guid=a610166aaed5b8adc8e17e040000001d"
Connected to accessibility bus at:  "unix:abstract=/tmp/dbus-O7dlqekdI5,guid=a610166aaed5b8adc8e17e040000001d"
Registered DEC:  true
Registered event listener change listener:  true
QSpiAccessible::accessibleEvent not handled:  "8008"  obj:  QObject(0x0)  " invalid interface!"
QSpiAccessible::accessibleEvent not handled:  "8008"  obj:  QSidebar(0xb7de550, name = "sidebar") "sidebar"
FIXME: handle dialog start.
Interface is not valid
ASSERT failure in : "Got an update for an invalid inteface. Investigate this.", file atspiadaptor.cpp, line 899
Aborted (core dumped)
As I have another HD with Ubuntu 14.04 install LibreCad and tried the same file save and it work
perfectly.
I hope this will help
Thank you
Re: crash on saving
this seems to be a qt-ai-spi bug,
https://bugs.launchpad.net/ubuntu/+source/qtiplot/+bug/997462
Please remove the package qt-ai-spi and try again.
Re: crash on saving
Lumaja
Apologize for my ignorance
How to remove the package  qt-ai-spi ?
Thank you
Re: crash on saving
sudo apt-get uninstall qt-at-spi
Please have a look at https://help.ubuntu.com/12.04/serverguide/package-management.html
Thank you
Re: crash on saving
Lumaja
Following your advised the result:
luis@luis-G41M-Combo:~$ sudo apt-get --purge remove qt-ap-spi
[sudo] password for luis:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package qt-ap-spi
I was expecting for this to be fixed
Cant find qt-ap-spi
 anywhere.
Re: crash on saving
 sudo apt-get --purge remove qt-at-spi
Cant find qt-ap-spi
 anywhere.
