display "side-scale"
ed_b@nger
How do i display a x,y scale on the side in the Layer Window such as its possible with Qcad?
Re: display "side-scale"
Ed (assuming…)
currently LibreCAD doesn’t support that.
Ries
On Apr 20, 2014, at 7:39 PM, ed_b@nger [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/display-side-scale-tp5709827.html
To start a new topic under Troubleshooting, email [hidden email]
ed_b@nger
ok thanks. so, my problem: i want to trace a pencil sketch to librecad. so actual i have the dimensions, which i want to have with it. when i do a circle, line or else, how do i know how big it is without counting the grids?
edit: Ok i think i got it. the only clue is the counter on bottom left an it was a question of setting the scale. Is there an option to save the set settings?
ps: an kind of Ruler on the sides would be useful though.
Ed,
although I would recommend to trace the pencil sketch in inkscape, you could just draw it in LibreCAD not worrying about the size.
Once this is done simply scale it to the desired size.
Place two lines horizontally separated by the desired dimension, then scale down/up your sketch to the desired height.
On Apr 21, 2014, at 2:55 AM, ed_b@nger [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/display-side-scale-tp5709827p5709829.html
