dxf library reader
dxf library reader
gnagno91
Hi!
To add the read support for TEXT should I modify the libdxfrw package, right? in dxflib there are only the function to rea from a file which are used in libdxfrw package?
Luca
Re: dxf library reader
Luca,
we should be using libdxfrw Rallaz can help you with that.
When I quickly grep the source code I see classes for MTEXT and TEXT (line 443 of drw_entities.h)
Ries
On Apr 17, 2012, at 8:03 AM, gnagno91 [via LibreCAD] wrote:
Hi!
The reader support for TEXT entity should be added in the package dxflib, too or only in libdxrw?
Luca
http://forum.librecad.org/dxf-library-reader-tp5646518p5646518.html
Both libraries have support for read and write TEXT & MTEXT.
to read TEXT with dxflib see rs_filterdxf.cpp line #560
void RS_FilterDXF::addText(const DL_TextData& data)
to write TEXT with dxflib seers_filterdxf.cpp line #1551
void RS_FilterDXF::writeEntity(DL_WriterA& dw, RS_Entity* e, const DL_Attributes& attrib)
to read TEXT with libdxfrw see rs_filterdxfrw.cpp line #531
void RS_FilterDXFRW::addText(const DRW_Text& data)
to write TEXT with libdxfrw see rs_filterdxfrw.cpp line #1737
void RS_FilterDXFRW::writeEntity(RS_Entity* e)
gnagno91
I looked to the the references you listed. I saw that in rs_filterdxfrw.cpp at the end of void RS_FilterDXFRW::writeInsert (line #1900) there is the call to the writeMText of the dxfRW class. Should I also implement the writeMText in rs_filterdxfrw.cpp, right? Sorry for my sometimes stupid question but I want to be sure of what I will do to not waste time.
Thank you a lot,
Luca
The line number have changed with my last commits and have started the write part for you.
rs_filerdxfrw.cpp line #1602 say:
    case RS2::EntityInsert:
        writeInsert((RS_Insert*)e);
        break;
    case RS2::EntityText:
        writeMText((RS_Text*)e);
        break;
/*    case RS2::EntityMText:
        writeMText((RS_MText*)e);
        break;*/
    case RS2::EntityDimLinear:
change to:
        break;
    case RS2::EntityText: //the e->rtti() type of single line text
        writeText((RS_Text*)e); //function to implement call with the "single line class"
        break;
    case RS2::EntityMText: //the e->rtti()type of multi-line text
        writeMText((RS_MText*)e); //existing function call with the "multi-line class"
        break;
rs_filerdxfrw.h line #128 say:
    void writeSpline(RS_Spline* s);
    void writeInsert(RS_Insert* i);
//    void writeText(RS_Text* t);
    void writeMText(RS_Text* t);
    void writeHatch(RS_Hatch* h);
change to:
    void writeText(RS_Text* t); //function to implement call with the "single line class"
    void writeMText(RS_MText* t); //existing function call with the "multi-line class"
