example draw
25 messages Options
12
Re: example draw
claus82
@ clive: no, I cant, because I am not able to do that, but if you or anyone can, I sure give my permission!
And I suggest to put the file down here, because in order to be put on wiki, I had to add some info about raster!!! Anyway...
In the file there are:
- the entire tutorial (pdf)
- the drawing (pdf format and dxf format)
- the image "raster.jpg"
...so... get it! It is a simple zip file, everybody should be able to extract the files!
(REMOVED, I SUGGEST TO DOWLOAD THE NEW ONE!)
p.s. if there is any problem I'll put the single files separately
Re: example draw
claus82
Fine, here in the file there are:
Et voilĂ , that's for you!
And this time I think it is everything pretty correct!
Don't forget to say if I made mistakes!!!
Removed... (hopefully for the last time) Look down
Claus
Re: example draw
onone
p.3
ecc
p.5
cop
p.6
create the others rectangles
 endpoint t the
adjacent
p.8
find as simple way
p.9
so thank to to the
Each map mus have
p.12
just co copy those
p.13
Firs, there is
the Sun rays
p.15
image on LibreCad
Re: example draw
claus82
To all: I am sorry that I have not much time to check what I do, but I am always looking for a job, so be patient with me...
to onone: thanks a lot, your help is very important, thanks again!
See ya!
Anyway here the file!!!
(friends, the tutorial has been moved to "LibreCAD Tutorials and Manual/Wiki topics" section in the forum)
Re: example draw
onone
...I am sorry that I have not much time to check what I do, but I am always looking for a job, so be patient with me...
no problem dude, looking for a job is more important.
Thanks.
12
