hatch
8 messages Options
hatch
jefken
I have a problem with hatch in 2.2.0 rc1 as seen in the attached photo
https://i.imgur.com/9UgzD15.jpg
what do I wrong?
gepensioneerd ingenieur
Gent België
LibreCad 2.2.0 rc1 Windows
Re: hatch
LibreCAD doesn't like nested hatching, closed loops in the hatching area. Separate the areas by making of an O a C with touching ends or from a rectangle two adjacent L's.
Re: hatch
jefken
OK I understand that dellus,
but why?
Here a screen without solid fill
[img]https://i.imgur.com/atIJvyk.jpg[/img]
and here the screen with solid fill
[img]https://i.imgur.com/JUbax7h.jpg[/img]
Why why this difference between fill activated or not activated?
Gent België
Re: hatch
I don't know why there is a difference between solid fill and true hatch. Must be a matter of the coding under the hood. Some while (years?) ago there was a discussion here on the forum on this issue. I don't find it anymore. I made some experiments then, have forgotten the details. Anyway, I remember that LibreCAD is very sensitive to the order the outline definition points are set. It may help to split up the areas further to avoid getting these twisted fill areas.
Generally hatching has weaknesses in LC which need improvement.
Re: hatch
In reply to this post by jefken
jefken,
hatch and solid fill using different techniques.
For hatch a repeated pattern is used and stenciled with the contour.
The direction and order of contour entities doesn't matter here.
But for solid fill a flood fill algorithm is used. For this the direction and order of entities is relevant.
And the algorithm has to detect what is outside and inside and this seems to be buggy.
I had the idea to use polylines for the contour, but this failed too. The result is different, but still invalid.
So if you need solid fill for your drawing I recommend dellus' advice.
Re: hatch
jefken
Ok thanks
Jozef Bronselaer
Op vr 15 mrt. 2019 12:45 schreef LordOfBikes [via LibreCAD] <[hidden email]>:
jefken,
http://forum.librecad.org/hatch-tp5717084p5717094.html
To unsubscribe from hatch, click here.
Gent België
Re: hatch
jefken
I have followed all recent tips and split them into individual zones and here are the results. There are no problems then.
[img]https://i.imgur.com/oqMacUX.jpg[/img]
[img]https://i.imgur.com/ArpK6PM.jpg[/img]
I hope that adjustments will be made to hatch in the future so that it becomes a bit easier.
I am just a simple user and unfortunately not a developer.
I have a lot of respect for the many developers of this wonderful CAD program. I used to be an autocad user, but this is too expensive for use by a non-professional user.
jefken
Gent België
Re: hatch
jefken
Here a screenshot of my different hatch in my drawing
[img]https://i.imgur.com/9BXfJvA.jpg[/img]
Gent België
