how to create closed polygons?
Jopeto
I recently switched from AutoCAD to LibreCAD and since I was quite a basic user, the transition was very smooth. I just have a few questions:
1. In AutoCAD when drawing a rectangle, the resulting rectangle is a closed polygon, however in LibreCAD it appears that the drawn rectangle is just a collection of 4 line segments. Is there a way to make sure that the resulting rectangle is closed? (I guess having a closed polygon is different from grouping all the line segments together)
2. In AutoCAD there is a feature, where if you select and object and then right-click and choose properties from the pop-up menu, you can edit the location of the vertices. I guess the equivalent in LibreCAD is chosing Modify->Edit Entry Geometry. However if I do that for a rectangle, it doesn't change the vertex of the rectangle, but just lengthens or shortens one of the line segments. I guess that goes back to my first question.
Thank you very much in advance!
Re: how to create closed polygons?
ClaudeQC
On 2012-10-14 09:48, Jopeto [via LibreCAD] wrote:
 > Hello,
Hello Jopeto,
 > I recently switched from AutoCAD to LibreCAD and since I was quite a
 > basic user, the transition was very smooth. I just have a few
 > questions:
 > 1. In AutoCAD when drawing a rectangle, the resulting rectangle is a
 > closed polygon, however in LibreCAD it appears that the drawn
 > rectangle
 > is just a collection of 4 line segments. Is there a way to make sure
 > that the resulting rectangle is closed? (I guess having a closed
 > polygon
 > is different from grouping all the line segments together)
 > 2. In AutoCAD there is a feature, where if you select and object and
 > then right-click and choose properties from the pop-up menu, you can
 > edit the location of the vertices. I guess the equivalent in LibreCAD
 > is
 > chosing Modify->Edit Entry Geometry. However if I do that for a
 > rectangle, it doesn't change the vertex of the rectangle, but just
 > lengthens or shortens one of the line segments. I guess that goes
 > back
 > to my first question.
- As you may already noticed, LibreCAD do not support "Rectangle"
   entity, but just drawing rectangle using lines.
   This can be easily seen, when selecting "Draw" menu.
   i.e.: There is no "Draw"->"Rectangle",
   but just "Draw"->"Line"->"Rectangle".
- I see 2 alternatives to have something that behave more like
   a "Rectangle" entity:
        1) Draw a rectangle using a "Polyline" entity.
        2) Draw a rectangle using "Line" entity
           ("Draw"->"Line"->"Rectangle"); then
           create a "Block" using the 4 resulting lines.
Remark:
        - If you want "Rectangle" entity supported by LibreCAD,
          you can fill a feature request here:
Hope it help,
Claude
Jopeto
Hello Claude,
Thanks a lot for your reply.
This is what I needed. After drawing a rectangle using polyline, I go to Modify->Edit Entry Geometry and click the selection box "Closed". This seems to give me a closed rectangle, which is what I need.
Thanks once again. Very helpful!
ClaudeQC
On 2012-10-17 00:35, Jopeto [via LibreCAD] wrote:
 > Hello Claude,
Hello Jopeto.
 >  > 1) Draw a rectangle using a "Polyline" entity.
 > This is what I needed. After drawing a rectangle using polyline,
 > I go to
 > Modify->Edit Entry Geometry and click the selection box "Closed".
 > This
 > seems to give me a closed rectangle, which is what I need.
- You can avoid the "Modify"->"Properties" step by drawing
   the Polyline entity (rectangle) the following way:
        1) Select "Draw"->"Polyline"->"Polyline".
        2) Draw the rectangle by specifying the 4 points,
           then click on the "Close" button in the Polyline
           tools bar, located at top of the drawing window.
Claude
