how to offset a geometry
9 messages Options Options
KRIS
Re: how to offset a geometry
KRIS
modify -> offset
line->parallel
polyline-> create equidistant polylines
In reply to this post by KRIS
commands: o, pa
http://wiki.librecad.org/index.php/Commands
It needs updating...
KRIS
thank you , but the connection is not closed
You can close the lines manually with modify - trim two.
Or you can make several objects into one with polylines - create polylines from existing segments and then apply create equidistant polylines.
KRIS
okay but there is always an angle which is not closed.
for only okay, but I have to do 200 different forms on the same design
Either close it with the 'tool options' toolbar, at the end of making the geometry,
or use modify -> properties (mp).
Hm... it looks like changing the properties only creates a beveled corner (if you use it after offset).
