mac magic mouse inconsistent with trackpad
1 message Options
ken rector
The Mac Magic Mouse does not perform well with LC when device option is set to mouse. Its actions are not consistent with the Mac trackpad.  I believe it is unusable as an LC device.
When device options are set to trackpad, the mouse actions are the same as the trackpad and both work correctly.
Device Options set to mouse:
(using magic mouse)
Using one finger, up, down, side to side.
Causes zoom at very high resolution.
After several zooms the image will diminish/increase in size and disappear with out moving fingers.
Depress Command while rubbing scrolls up, down and side to side normally.
(using trackpad)
Using two fingers, up, down, side to side.
Device Options set to Trackpad:
(using magic mouse)
Scrolls up, down, side to side normally.
Depress Command while rubbing zooms in, out normally.
(using trackpad)
Version: 2.2.0
Compiler: Clang 13.0.0
Compiled on: Dec 17 2022
Qt Version: 5.15.7
Boost Version: 1.80.0
System: macOS 10.15
