new user
9 messages Options
new user
whillyjo
just started using the system.  work very well, but an encountering two problems....
I can only get 3 lines on mult line text, and the ellipse function inscribed in four lines does not always work for me in that i can specify 3 lines, but the system does not allow me to click on a forth line.
Re: new user
sp1der
Hi, I cannot reproduce these problems.
Are you using the latest version of LibreCAD?
What operating system are you using?
Can you attach a sample file here on the forum for testing?
Re: new user
whillyjo
test_file_for_blog.dxf
here is a file with a examples of both problems.
many thanks.
Re: new user
whillyjo
I'm using Windows 7 Home Premium and the version of LibreCAD is 2.0.2
Thanks.
Re: new user
In reply to this post by whillyjo
this is one algorithm issue.
For a parallelograms, there are infinite number of possibilities for inscribed ellipses, and the current algorithm only handles when there's an unique inscribed ellipse for 4 given lines.
Re: new user
whillyjo
thanks for the input.
one thing that I noticed is that when I make the parallelagram as a string (that is construct it by drawing lines via two points and getting all four sides completed with 5 clicks), it seems to work better.
Any help on the multi line text?
Re: new user
it works properly for me
mtext
Re: new user
whillyjo
it looks like it does.
For me, i just get an outline box instead of letters.
the box seems to be of a size that would contain all of the lines and letters, so it changes with the number of lines of text and the length of the text line, but all I get is the simple white lined box until i delete some lines or characters from the lines.
Any idea??
thanks for your help so far!
Re: new user
whillyjo
this is what i got for the four lines of text that i tried to put on the drawing, versus what you show.
