no member named 'unique_ptr' in namespace 'std'
7 messages Options
dreylago
Hi community,
I just cloned the repository, followed the homebrew install instructions in OSX,  and tried to compile . The following is the very first warning and the  first error message that followed. Any help is appreciated.... thanks....
g++ -c -pipe -g -O2 -Wall -W -fPIC -DQT_NO_DEBUG -I../../mkspec/macports -I. -I/usr/local/Cellar/qt/4.8.7/include -I../../generated/lib/libdxfrw/moc -o ../../generated/lib/libdxfrw/obj/libdwgr.o src/libdwgr.cpp
In file included from src/dl_writer_ascii.cpp:34:
src/dl_exception.h:51:9: warning: private field 'groupCode' is not used
      [-Wunused-private-field]
    int groupCode;
1 warning generated.
g++ -c -pipe -g -std=c++11 -O2 -Wall -W -fPIC -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SHARED -I../../mkspec/macports -I. -I/usr/local/Cellar/qt/4.8.7/lib/QtSvg.framework/Versions/4/Headers -I/usr/local/Cellar/qt/4.8.7/lib/QtSvg.framework/Versions/4/Headers -I/usr/local/Cellar/qt/4.8.7/include -I../../generated/lib/jwwlib/moc -F/usr/local/Cellar/qt/4.8.7/lib -o ../../generated/lib/jwwlib/obj/dl_jww.o src/dl_jww.cpp
src/muParserTokenReader.cpp:151:10: error: no member named 'unique_ptr' in
      namespace 'std'
    std::unique_ptr<ParserTokenReader> ptr(new ParserTokenReader(*this));
Re: no member named 'unique_ptr' in namespace 'std'
Hi dreylago,
Just double checked: the MuParser code is correct with <memory> header for unique_ptr
You compiling command contains -std=c++11
I'm lost here, if the compiler is too old: g++-4.6 or earlier, -std=c++11 should have been rejected.
still, what's your gcc version?
g++ -v
dreylago wrote
Hi community,
    int groupCode;
      namespace 'std'
dreylago
$ g++ -v
Using built-in specs.
COLLECT_GCC=g++
Target: x86_64-apple-darwin13.4.0
Configured with: ../configure --build=x86_64-apple-darwin13.4.0 --prefix=/usr/local/Cellar/gcc48/4.8.4 --libdir=/usr/local/Cellar/gcc48/4.8.4/lib/gcc/4.8 --enable-languages=c,c++,objc,obj-c++ --program-suffix=-4.8 --with-gmp=/usr/local/opt/gmp4 --with-mpfr=/usr/local/opt/mpfr2 --with-mpc=/usr/local/opt/libmpc08 --with-cloog=/usr/local/opt/cloog018 --with-isl=/usr/local/opt/isl011 --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --disable-werror --with-pkgversion='Homebrew gcc48 4.8.4' --with-bugurl=https://github.com/Homebrew/homebrew-versions/issues --enable-plugin --disable-nls --enable-multilib
Thread model: posix
gcc version 4.8.4 (Homebrew gcc48 4.8.4)
I am also confused by this... as the flags and version seem correct.
One thing:
your gcc is at : /usr/local/
if it's not by MacPorts, could you try gcc from MacPorts?
dreylago wrote
$ g++ -v
COLLECT_GCC=g++
Thread model: posix
On Sep 24, 2015, at 5:12 PM, dxli [via LibreCAD] <[hidden email]> wrote:
One thing:
dreylago wrote
$ g++ -v
COLLECT_GCC=g++
Thread model: posix
I have seen something like this before.
Ensure you don't change your GCC to something else.
Ries
dreylago
Is it ok to mix homebrew with MacPorts gcc? my gcc was installed with homebrew. Should I uninstall it first?
Thanks
just try any other (newer) gcc
You can also download Qt-5 (the latest version) and use clang comes with it.
Thanks
