problem with the character when i work
godetti
hi
sorry i  am new on the forum
i have a 2.2.02 version
until yersterday all the application  was efficient, but suddently in the morning it  doesn t    want to appear all the caracter or the number  (letter and numbers) on the screen, however if i go in the "view before printing" all is good
this problem doesnt allow me to work, because  i need to mesure allthe things xhen i work
in  all this time nothing another program was  been loaded
i try to run again the pc                      nothing is better
i get twice again   to remove and after to the load  librecad   nothing is better
excuse me  for my bad english language i  don t if i can write infrenc
have you see this problem  what can i do
Re: problem with the character when i work
perepujal
Maybe you have Draft mode enabled? If so, then disable it.
It also could be something in the lines of what happened there
https://forum.librecad.org/Invisible-with-Text-not-related-to-Draft-Mode-td5722882.html
HTH
Pere
