problems in opening librecad files
sarodimauro
When I open a file already saved with Librecad, it opens with Autodesk dwg true view and I do not know what to do. Can you help me?
Re: problems in opening librecad files
You mean, when you double click on a DXF file in the file browser, it opens with True View?
I assume you have installed True View recently. This may have modified the default application setting for DXF files.
You can reset or change it to LibreCAD, but that depends on your operating system.
Or you open LibreCAD first and the select File -> Open... to open the DXF file in LibreCAD.
R: problems in opening librecad files
sarodimauro
In reply to this post by sarodimauro
Armin,
Yes, when I was double-clicking on a DXF file in the file browser, it opened with True View!
My operating system it’s windows 10.
Armin, as per your suggestion, I opened LibreCAD first > select File > open the DXF saved file and it’s OK.
Many thanks and congratulations
Saro
Da: LordOfBikes [via LibreCAD] [mailto:ml+[hidden email]]
Inviato: giovedì 7 dicembre 2017 08:12
A: sarodimauro <[hidden email]>
Oggetto: Re: problems in opening librecad files
http://forum.librecad.org/problems-in-opening-librecad-files-tp5715563p5715565.html
To unsubscribe from problems in opening librecad files, click here.
