"Select entities to order" after input any command
simonlau
I'm new to LibreCAD.
I was trying to use the command input but I got stuck at command.
Whatever I type in the command input area , such as "rec", it displays "Select entities to order"  after I press enter. Or when I try to draw a circle, after I type in the center point "0,0", it also displays "Select entities to order".
What did I do wrong?
My software info:
OS:MacOS Mojave 10.14.5 (18F132)
Version: 2.1.3
Compiler: Clang 8.0.0
Compiled on: Sep 22 2016
Qt Version: 5.6.1
Boost Version: 1.60.0
Re: "Select entities to order" after input any command
The message "Select entities to order" comes from one of the order tools.
This means, that any of the order tools is active then.
Maybe you push any of the order tool hot keys Home/End/PgUp/PgDn?
Look at the Tools -> Modify -> Order menu to see the hot keys, possibly this is an issue on Mac OS.
simonlau
I tried typing in the commands without touching any unnecessary keys, still got the same results.
Tools -> Modify -> Order menu shows PageUp(which is Fn+up arrow on Mac), PageDown (which is Fn+down arrow on Mac), Up arrow and Down arrow for short cuts and I'm 100% sure those keys are not touched either before or after inputting the commands.
