section
section
Lucio Pannitteri
I sometimes have a problem with the section function. There is no problem when I perform the section on a simple geometry, but if the section geometry is more complex with multiple edges, for example, it simply does not perform the section. In these cases, I use the "divide" function to divide the various points of the geometry. This way, but it does not always perform the section. In these cases, I use the 45-degree segment function and fill in the cut part. But evidently I am making some mistake, what should I do? I imagined that the problem occurs when a line is common to other geometric spaces, but if so, it should not work even when the cut represents the simple geometric figures I mentioned earlier. Could someone help me?
Re: section
Do you mean trim/divide?
In general, we do not handle splines well.
