segment avec 4 contraintes
rclerc
Bonjour,
je veux tracer un segment ayant les contraintes suivantes :
- longueur connue
- horizontale
- une extrémité sur un cercle
- L'autre extrémité sur un autre cercle
y a-t-il un moyen de faire ce segment, sans calculer les positions (Thalès)
merci d'avance
Richard
Re: segment avec 4 contraintes
If I understood your question correct, with the help of google translator
rclerc wrote
I want to draw a segment with the following constraints:
- known length
- horizontal
- one end on a circle
- The other end on another circle
 I got this solution:
Make a copy of the left circle, by the known distance to the right side, to get the red circle.
Make a copy of the right circle, by the known distance to the left side, to get the green circle.
Use the command line for exact distance, e.g. move reference 0,0, move to 20,0 or -20,0.
Use the intersection snap tool to draw the magenta line.
This line is horizontal, with a length of the known distance.
Then you can delete the red and green circles, done
rclerc
genial !!!!
merci !!
thanks a lot !
