text won't show
text won't show
kdwiz57
Hi everybody,
I'm new to librecad. Ran into something that stumps me. Did a drawing of a clock. put the clock numbers on the face then moved the center of the face to X0,Y0. Now the numbers 1,2,3,4 and 5 show up as the text numbers. OK. But now every text left of x show only as a box (no numbers 6.7.8.9.10.11 and 12). Any suggestion as to how I can get the numbers to appear
Re: text won't show
Try autozoom, or undo and redo, or save, close and reopen the drawing.
Re: text won't show
kdwiz57
I've auto zoomed, saved and reloaded. If I move it to the right ( the entire drawing) then they show up. move it back to center then they disappear again. Maybe in drawing setting....I'm not sure. Thanks for the suggestions.
Re: text won't show
I have drawn a clock like you did and moved it to center, experienced the disappearance of 6 to 12, but after applying undo and redo or zooming around, this was gone. So I couldn't reproduce the behavior you described. Version 2.1.3. I am clueless.
