1/4 inch scale
12 messages Options
1/4 inch scale
JDelgado0311
I want to produce drawing that are 1/4" = 1.0'-0".  I think this means a 1:48 ratio.  In libreCAD, it skips 1:48 and goes from 1:32 to 1:64.  How do I set the scale to 1:48 so that I can produce an Architectural drawing?
Thanks in advance
Jesse
Re: 1/4 inch scale
sp1der
In print preview, overwrite in the scale field and tick the 'fixed' box.
Re: 1/4 inch scale
JDelgado0311
Thanks!
Re: 1/4 inch scale
JDelgado0311
In reply to this post by sp1der
So, I thought I had this figured out.  I set my paper size to ARCH D (24 x 36 inch) and my scale to 1:48.  I then made a drawing (using feet as units).  When I go to print the paper is supper tiny relative to my drawing.  It only fits if I set the scale at ~1:500.
Any ideas?  I've uploaded my file
Site_Plan_-_need_to_scale.dxf
Re: 1/4 inch scale
It turned out to be a LC bug in paper handling. Basically, it prints to A4 paper size whenever the paper size is not supported by Qt natively.
This bug should be fixed before the 2.0.7 release.
We should provide explicit control on offset/insertion point for print preview in the print preview toolbar. Currently, it can be dragged, but does not accept numbers/coordinates as offset.
Re: 1/4 inch scale
JDelgado0311
Thank you.  I'll keep an eye out on the nightly builds.
Re: 1/4 inch scale
In reply to this post by JDelgado0311
if you can build from source, please test this commit:
https://github.com/LibreCAD/LibreCAD/commit/4c7b6f28fc2c223c83ca14036592112ccb34f198
Re: 1/4 inch scale
A Nightly Build including this commit is available now.
LibreCAD-Installer-2.0.6-71-g4c7b6f2.exe
Re: 1/4 inch scale
JDelgado0311
Sorry,
I unable to build at this time.
Thank you!
Re: 1/4 inch scale
JDelgado0311
Oops! I replied before seeing you new post.
I just downloaded the new build.  I'll try it out and let you know if it fixed the problem.
Thanks Again.
Re: 1/4 inch scale
JDelgado0311
Unfortunately,  The changes don't appear to have solved the issue.  Please, see the enclosed files.
Lot_plan.dxf
Thanks for all your help.
Jesse
Re: 1/4 inch scale
what's the issue?
looks like that in your Lot_plan.dxf,  there's a confusion between units feet and inches.
As your drawing is in inches, but the drawing options specifies "feet". If you want a fixed scale of 1:32, 1:384 should be used.
scale.pdf
Lot_plan.dxf
Jesse
