2.2.0-rc2 fails to install on BigSur 11.1
23 messages Options
2.2.0-rc2 fails to install on BigSur 11.1 – Well, I lost my patience after 30 minutes looking at the white "welcome" window. Any suggestions? MacBookAir - M1 chip - 16GB - Big Su...
LibreCad 2.2.0 Mac OS X Big Sur – Hi Anyone experience problem with LibreCad and Mac OS X Big Sur? Best regards Peter
2.1.3 release works fine so I will use that instead
Many thanks for reporting this. Have you tried older packages too? It's important to know, if this is a problem with -rc2 only or if the older p...
Re: Test new macOS package – Hello. I have just downloaded the V2 dmg package and installed it on a machine running Big Sur 11.1. The package appears to install OK but does...
Can you please add information about your Mac hardware.
I tried the rc1, with identical result. I will try older packages and report back.
They were all build in the same environment, so I expect same results, don't put too much effort in this. The question for me was if something ha...
Hi Lord, version 2.13 installs & starts in a matter of seconds. No suspicious CPU / GPU activity recorded like described from recumberic. ...
Hi @Lord and @Catalys I also had problem on 2.2-0.rc-2 .dmg on my MacBook Pro i7, Big Sur 11.1. Application start hanging and does not start....
Many thanks @savokov for your efforts. I can't prove this, but my assumption is not the app, but some libraries may be missing or different on ...
LibreCAD & Mac BigSpur – I have tried various different sources and versions but Mac's BigSpur operating system will not allow LibreCAD to be installed. Mac OS wants to i...
I was trying with V2.2 in my MacBook Pro M1 and you can not even open it. I went back again with V2.1.3. I hope you can fix this soon :)
2.2.0 RC2 does not like my Intel 2015 MacBook Pro with macOS 11.1. It hangs with a blank outline of the Welcome screen. 2.1.3 seems fine. I'm n...
I've got a new DMG package which was build by a community member on Big Sur, but not on a M1 system. Many thanks! It can be downloaded now from...
Thank you Armin. The build from LibreCAD-2.2.0-rc2-BigSur.dmg loads fine on my Intel Mac with macOS 11.2.1.
Hello, LibreCAD-2.2.0-rc2-BigSur.dmg seems working fine on my Macbook Air M1 (macOS 11.2.1). (LibreCAD-2.2.0-rc2.dmg did not work) Thank yo...
Just wanting to confirm succesfull installation and running: LibreCAD-2.2.0-rc2-BigSur.dmg: Version: 2.2.0-rc2 Compiler: Clang 12.0.0 Compil...
Great to hear that! Many thanks @chazzo, @MizTor and @Twist for reporting.
Chiming in that this is working on my Macbook Pro with the M1. Hopefully this isn't a necro post, there is a link to it in the downloads page to r...
Re: LibreCAD & Mac BigSur – Hi Armin, finally time for my requote: your new DMG package works quite well on my Mac Air with M1 and Big Sur 11.2.3 (20D91) Many thanks fo...
Glad to hear that. Many thanks for your report.
I have just tried to install 2.1.3 on my OS X Big Sur (11.2.3) and it crashed. My system is: Model Name: MacBook Pro [2019] Model Identifier...
