2.2.0-rc2 fails to install on BigSur 11.1
23 messages Options
2.2.0-rc2 fails to install on BigSur 11.1 – Well, I lost my patience after 30 minutes looking at the white "welcome" window. Any suggestions? MacBookAir - M1 chip - 16GB - Big Su...
LibreCad 2.2.0 Mac OS X Big Sur – Hi Anyone experience problem with LibreCad and Mac OS X Big Sur? Best regards Peter
2.1.3 release works fine so I will use that instead
I have just tried to install 2.1.3 on my OS X Big Sur (11.2.3) and it crashed. My system is: Model Name: MacBook Pro [2019] Model Identifier...
LibreCAD & Mac BigSpur – I have tried various different sources and versions but Mac's BigSpur operating system will not allow LibreCAD to be installed. Mac OS wants to i...
I was trying with V2.2 in my MacBook Pro M1 and you can not even open it. I went back again with V2.1.3. I hope you can fix this soon :)
2.2.0 RC2 does not like my Intel 2015 MacBook Pro with macOS 11.1. It hangs with a blank outline of the Welcome screen. 2.1.3 seems fine. I'm n...
I've got a new DMG package which was build by a community member on Big Sur, but not on a M1 system. Many thanks! It can be downloaded now from...
Re: LibreCAD & Mac BigSur – Hi Armin, finally time for my requote: your new DMG package works quite well on my Mac Air with M1 and Big Sur 11.2.3 (20D91) Many thanks fo...
Glad to hear that. Many thanks for your report.
Thank you Armin. The build from LibreCAD-2.2.0-rc2-BigSur.dmg loads fine on my Intel Mac with macOS 11.2.1.
Hello, LibreCAD-2.2.0-rc2-BigSur.dmg seems working fine on my Macbook Air M1 (macOS 11.2.1). (LibreCAD-2.2.0-rc2.dmg did not work) Thank yo...
Just wanting to confirm succesfull installation and running: LibreCAD-2.2.0-rc2-BigSur.dmg: Version: 2.2.0-rc2 Compiler: Clang 12.0.0 Compil...
Great to hear that! Many thanks @chazzo, @MizTor and @Twist for reporting.
Many thanks for reporting this. Have you tried older packages too? It's important to know, if this is a problem with -rc2 only or if the older p...
Chiming in that this is working on my Macbook Pro with the M1. Hopefully this isn't a necro post, there is a link to it in the downloads page to r...
I tried the rc1, with identical result. I will try older packages and report back.
They were all build in the same environment, so I expect same results, don't put too much effort in this. The question for me was if something ha...
Hi Lord, version 2.13 installs & starts in a matter of seconds. No suspicious CPU / GPU activity recorded like described from recumberic. ...
Hi @Lord and @Catalys I also had problem on 2.2-0.rc-2 .dmg on my MacBook Pro i7, Big Sur 11.1. Application start hanging and does not start....
Many thanks @savokov for your efforts. I can't prove this, but my assumption is not the app, but some libraries may be missing or different on ...
Re: Test new macOS package – Hello. I have just downloaded the V2 dmg package and installed it on a machine running Big Sur 11.1. The package appears to install OK but does...
Can you please add information about your Mac hardware.
