Command Line Parsing
1 message Options
I assume the command line will develop into scripting so it is worth a bit of consideration.
Why the Command Line kinda sucks:
* pasting multiple lines is a separate option to typing - pasting and typing should be the same, a single command should be a multiple of one (ie no special case) supporting various eol
* comma between parameters - a space would be easier and a tab a good option
* multiple commands can be separated with a semicolon - whatever, seems redundant as a new command should start after all parameters for the previous command
* parametric scripts aren't supported - Pseudo Scripting With Excel workaround would be even better with openpyxl under python
* no comment command - a file full of commands needs comments
