Compiling with dwg support
hsrai
I tiried to compile:
https://github.com/Rallaz/LibreCAD/archive/dwgsupp2.zip
What is wrong, if it throws following error:
make[3]: Entering directory `/home/tcc/Documents/HSRai/Programming/LC/DWG/LibreCAD-dwgsupp2/tests/libraries/libdxfrwtest'
g++ -c -pipe -std=c++0x -O2 -Wall -W -D_REENTRANT -DQT_WEBKIT -DDRWG_DBG -DDRWG_TEST_DIR=\"/home/tcc/Documents/HSRai/Programming/LC/DWG/LibreCAD-dwgsupp2/tests/libraries/libdxfrwtest/../..\" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtSvg -I/usr/include/qt4 -I../../../libraries/libdxfrw/src -I../../../generated/tests/libraries/libdxfrwtest/moc -o ../../../generated/tests/libraries/libdxfrwtest/obj/dwgBuffer_test.o tests/dwgBuffer_test.cpp
tests/dwgBuffer_test.cpp:13:25: fatal error: gtest/gtest.h: No such file or directory
compilation terminated.
make[3]: *** [../../../generated/tests/libraries/libdxfrwtest/obj/dwgBuffer_test.o] Error 1
make[3]: Leaving directory `/home/tcc/Documents/HSRai/Programming/LC/DWG/LibreCAD-dwgsupp2/tests/libraries/libdxfrwtest'
make[2]: *** [sub-libdxfrwtest-make_default] Error 2
make[2]: Leaving directory `/home/tcc/Documents/HSRai/Programming/LC/DWG/LibreCAD-dwgsupp2/tests/libraries'
make[1]: *** [sub-libraries-make_default] Error 2
make[1]: Leaving directory `/home/tcc/Documents/HSRai/Programming/LC/DWG/LibreCAD-dwgsupp2/tests'
make: *** [sub-tests-make_default-ordered] Error 2
H.S.Rai
Re: Compiling with dwg support
Dwg support is a work in progres.
To compile are needed all dependencies of LibreCAD and google test:
http://code.google.com/p/googletest/
Another option is disable test build (only used in libdxfrw develop)
To disable comment line #7 in tests/libraries/libraries.pro (#        libdxfrwtest \)
hsrai
I now, it is "Work in progress". So I can act as tester ;-)
I tried to compile googletest. But need more help. Perhaps it needed to place at some suitable folder (as it is not installed systemwide).
So tried with disabling it.
Compiled successfully.
But on trying to  open a dwg file, it says: Can't open /path/to/file/foo.dwg Please check the permission.
--debug information is:
DXFRW Filter: importing file '/home/tcc/LCTest.dwg'...
RS_EntityContainer::RS_EntityContainer: owner: 1
RS_VariableDict::addVariable()
RS_FilterDXFRW::fileImport: reading DWG file
RS_FilterDXFRW::fileImport: reading DWG file: OK
RS_DialogFactory::instance()
RS_DialogFactory::instance(): OK
RS_DialogFactory::getFactoryObject
RS_DialogFactory::getFactoryObject: returning factory object
QG_DialogFactory::commandMessage
QG_DialogFactory::commandMessage: OK
RS_FilterDXFRW::printDwgError: DRW::BAD_VERSION
Cannot open DWG file '/home/tcc/LCTest.dwg'.
RS_FilterDXFRW::~RS_FilterDXFRW(): OK
RS_Graphic::open(/home/tcc/LCTest.dwg): OK
QC_MDIWindow::slotFileOpen: failed
QC_MDIWindow::slotFileOpen: OK
QG_GraphicView::paintEvent begin
QG_GraphicView::paintEvent end
QC_ApplicationWindow::slotWindowActivated begin
H.S.Rai
hsrai
I tested with following file created in DraftSight
LCTest.dwg
and many other AutoCAD files.
H.S.Rai
you have not read in the LC command line (marked in red)
Testers are needed, but, at the moment, only for implemented parts.
Implemented versions: R13, R14 & v2000
Implemented objects: linetype, layer, block & text style
Implemented entities: point, line, circle, arc, ellipse, ellipse arc, insert, lwpolyline & text
More entities & versions comming soon...
A example file from cben.net:
https://github.com/Rallaz/LibreCAD/tree/dwgsupp2/tests/libraries/dwgdevel/testfiles/R-2001-1.DWG
