Coordinate system conflict
Coordinate system conflict – in LibreCAD, the dares in the coordinate system increase in an an anticlockwise direction, starting at the righthand end of the X-axis. However, w...
LibreCAD can not switch to a different coordinate system. Only more advanced commercial CAD packages might have this option. LibreCAD is not prima...
Thanks, Delius. The thread does go into a little more detail on the issue. However, unfortunately, it doesn't give sufficient information to do th...
The conversion is no rocket science. For relative angles simply add a minus to revert the direction, this works in both directions. 30° geograph...
Thank you for this very clear explanation, LordOfBikes. I hav been wondering how difficult it would be to add the ability to switch from geogr...
