"Explode" tool localisation, and other.
ClaudeQC
- Hello,
- I want to talk about "Explode" tool localization.
- "Explode" tool is located at 3 different places in LibreCAD.
  It is localized in the "Modify" menu, in the "Block" menu, and
  in the "Edit" CAD tool bar.
- My point of view is that "Explode" is a tool to modify entities,
  and have not its place in the "Block" menu.
  So, ideally it must be removed from the "Block" menu.
- Also, in the CAD tool bar, naming the button that show up the
  tools that appear in the "Modify" menu as "Show menu "Edit"" is
  not correct.  It should be named "Show menu "Modify"".
- So, here is my proposal:
        1) Remove the "Explode" item from the "Block" menu.
        2) Change the name of the "Show menu "Edit"" button in the CAD
           tool bar to "Show menu "Modify".
Claude
Re: "Explode" tool localisation, and other.
Claude,
I am ok with the name change.
I would need to lookup if the Explode function in the Block menu calls up some different routines.
then the one in the menu...
Ries
On Jul 29, 2011, at 9:09 AM, ClaudeQC [via LibreCAD] wrote:
- Hello,
Claude
http://librecad.1049103.n5.nabble.com/Explode-tool-localisation-and-other-tp4647169p4647169.html
ClaudeQC
On 29/07/2011 10:43, R. van Twisk [via LibreCAD] wrote:
 > I am ok with the name change.
- Ok.  I will create a bug report in the Sourceforge bug tracker, and
   then, will modify and create the associated patch and put this
   patch in the Sourceforge patch tracker.
 > I would need to lookup if the Explode function in the Block menu
 > calls up some
 > different routines.
 > then the one in the menu...
Ok.  I will wait for your lookup result.
Claude
