Expression Syntax Error
Expression Syntax Error – Hi, I try to use the command lines but have an "Expression Syntax Error". Here is the code : c=10 d=\c+\c po \d,\d and the ans...
Hi Mathieu, this is a nice find. I even wasn't aware, that your working example is possible. Where is your knowledge abut this syntax from? ...
Hi Armin, thanks for your answer. I found the informations about command lines using variables on that webpage : https://librecad.readthedocs.io/...
