Gear contoure
9 messages Options
Gear contoure
eslavko
Hello...
How to make gear (involute) with librecad?
Thanks.
Re: Gear contoure
There's currently no native support for involute in LC.
I'm thinking about using the new interpolation spline to create a new type of entity.
Before the implementation is done for LC. You may try the equation plot plugin, as a workaround.
eslavko wrote
Hello...
Thanks.
Re: Gear contoure
eslavko
There is python script for FreeCad to create involute gear that can be maybe converted. But as I see in LibreCad there is no such features as plugin or other external modules.
eslavko wrote
Hello...
Thanks.
Re: Gear contoure
there's a plugin interface, and severalplugins are included in official releases.
actually, two official plugins can be helpful here:
plot math equation, since 2.0.4
read in ascii points
> type of entity.
>     eslavko wrote
>     Hello...
>     Thanks.
Re: Gear contoure
In reply to this post by eslavko
One more question:
What would be desirable ways to draw an involute?
For example, to draw a circle, we can have many ways:
1, center and radius;
2, center and a point on the circle;
3, 3 points on the circle;
4, tangential to 3 existing circles;
etc.
Re: Gear contoure
eslavko
On 10. 09. 2014 16:27, dxli [via LibreCAD] wrote:
> One more question:
> etc.
I was interestig to draw involute gear.
There should be more question. Position (probably center), number of
teeth, modulo (or diametral pitch & co) ...
Slavko.
Re: Gear contoure
eslavko
> official releases.
Ok I find that. But seems that for plugin I need to recompile LibreCAD.
It's not some scripting language...
Slavko.
Re: Gear contoure
gaganjyot
> One more question:
> etc.
Slavko.
Right now LibreCAD 2 doesn't supports scripting. We are in process of making a newer version of LibreCAD from scratch and has support for scripting using lua. Ries has ported the python script to Lua for LibreCAD.
You may see the demo here,
http://skitch.rvantwisk.nl/~rvt/bmk/tmp/LibreCAD_-20140409-162814.jpg
But since LibreCAD 3 is under heavy developement and read/write support for files is yet to be implemented, So at the moment if wont be available.
You can even check the code for Gear at
http://pastebin.com/ts3XCXqa
Thanks
Gaganjyot
Re: Gear contoure
James_S
I was about to suggest the same thing but you were first. I think this is the best way .
