Grid
Grid
oldschoolcowboy
Grid shows minor and major lets say I am zoomed in so it says 10/100. I have my preferred unit of measure set to inches.
I find nothing in the software that says what the 10/100 means in the way of actual units. So far I have been unable to find anything in the documentation about this.
Does the grid show my unit of measure? In my example above 10/100 is this 10 inches / 100 inches?
If that is not what the grid is representing then how exactly are we able to draw at full scale and have it at the correct size?
I am not concerned with scaling to fit a drawing.
I am focused on full scale models.
Re: Grid
oldschoolcowboy
Another way to ask this question: with my preferred units at 1 inch, starting a line at 0,0 and ending at 10,0 is that a 10 inch line sense I have my units at inches?
Or is all this just to have the proper scale for a print out on a paper?
This also obviously would be connected to the dimensions that show up in the print on paper.
Something seems way off but I can't figure out what it is.
Re: Grid
Land Owner
You set the Units:
Options ==> Current Drawing Preferences ==> UNITS (INCH for this example)
Then set the GRID
X and Y Spacing are the "Grid marks" when you want them shown.  The larger the number, the fewer and further between Grid marks.
At 10=X and 10=Y, there are 10" between every adjacent pair.
At 1=X, 10=Y there will be 10 x 1" Grid marks in the X direction for every 1 x 10" Grid mark in the Y even though, zoomed out, there are lines of intersection only at every 10".  Zoom in to see the smaller "X" marks.
